XY Axis Test Keeps Failing
StarSmash32
(@starsmash32)
Mitglied
Just finished assembling my printer and am running all of the calibration tests. Every test has passed so far except for the XY Axis test. It will fail the X axis after bumping the left side twice then speeding over to the right side. It will then tap the right side once and recenter. That will then give me a failed x test. It will then continue the test to give me a passing Y axis test and no pass or fail on the Z axis part of the test. This is my first 3D printer so I have no idea how to handle it from here.
Veröffentlicht : 23/07/2025 9:51 pm
LukeKS
(@lukeks)
Mitglied
RE: XY Axis Test Keeps Failing
Hi, I've had a simillar problem recently, but about a year after assembling the printer. Cleaning the rods and adding a bit of fresh grease, then moving the print head assembly by hand a bit seems to have fixed it, at least for now. But in your case, it's probably different. I'd try adjusting the belt slightly, I assume you've tightened it like the manual says, so maybe losen it a bit.
And if you have fixed the problem, please share it 🙂
Veröffentlicht : 09/08/2025 12:16 pm
