WiFi Misbehaving
This year, I upgraded my MK3 to the MK4. Super happy with it and have been printing quite a bit more lately (and have finally started creating my own designs).
This week, however, the WiFi seems to be erratic.
Symptoms:
- Not showing up as connected on PrusaConnect dashboard (shows as "Offline")
- Completed prints do show up on PrusaConnect (which seems to tell me some wifi connection is working at least intermittently)
- When checking the network status, the system will alternate between "connected" and "No AP" ever 5 - 10 seconds
- System seems to be recognized on my router (the IP is pinned, if that matters)
- The system has worked solidly without trouble for the last 6 months or so and only this week has had these problems
Troubleshooting steps:
- Restarted all wifi/internet equipment
- Restarted printer
- Flashed/updated the firmware to the latest version (6.1.2-7894)
- Recreated the wifi settings ini file via PrusaSlicer
I poked around here on the forum but found nobody with the same symptoms. A reddit search found one other person with similar behavior, but no soluiton.
For the short term, I can "sneaker net" my files back and forth to the printer via USB, but boy, I have quickly gotten spoiled by diretctly uploading the files to PrusaConnect and following the status from there!
Thanks for any help/advice y'all can provide.
Posted : 28/08/2024 10:16 pm
RE: WiFi Misbehaving
I am having similar issues. I moved to ethernet cable and some of the issues are still present.
Posted : 30/08/2024 11:58 am
