Where I have to mount the GPIO board?
chaoscrack
(@chaoscrack)
Hello
Today, I updated my MK4 to MK4S. At the same time, I wanted to install the GPIO board. In the help article, it is only described how to connect the wire but not how or where to I have to mount the board. Is this up to me?
Thanks for clarifying
Patrick
Opublikowany : 13/11/2024 6:16 pm
JP Guitars
(@jp-guitars)
RE: Where I have to mount the GPIO board?
There are a number of mounting solutions on Printables
Opublikowany : 13/11/2024 7:22 pm
chaoscrack
(@chaoscrack)
Thank you for the hint with printables.
However I was looking for, respectively I expected an official Prusa solution.
This model ( https://www.printables.com/model/1016997-prusa-gpio-hackerboard-cover) looks like what I'm looked for.
Opublikowany : 14/11/2024 6:34 am
JP Guitars
(@jp-guitars)
I think the problem with an official solution is by its very nature it is going to be fitted to a hacked printer, so there is no way to know what other hacks have been done and therefore it is impractical to have a standard way to mount it. For instance I can see people wanting to co-mount an Arduino or a Pi and different people will want different ways to have wires exiting the mount depending if they have soldered directly to the board or used header pins.
Opublikowany : 14/11/2024 8:33 am
