Weird marks on print
ASPRINT
(@asprint)
Hello Prusa Community!
Unfortunately I have been having a weird issue with each and every print since I upgraded to the MK4S from the MK4S. What happen is there are weird imperfections on every layer of the print. I tried a different filament, different print, and a different slicer with no luck. I then reached out to Prusa support on 3 separate occasions but had no luck fixing it. I have tried almost everything and am out of ideas. Please advise. Thanks so much for your help!
Sincerely,
ASPRINT
Attached is an image of a print with the imperfections
ASPRINT-(Proudly)MK4S MMU3 Owner
Opublikowany : 15/06/2025 8:04 pm
Mukluk Actual
(@mukluk-actual)
RE: Weird marks on print
Has anyone suggested over-extrusion as the cause?
If you're looking for a great resource, I recommend Sean Aranda's "3D Printing Failures; How to Diagnose and Repair All Desktop 3D Printing Failures."
https://www.amazon.com/dp/B09NH3BB9F?ref_=ppx_hzod_title_dt_b_fed_asin_title_0_0
Opublikowany : 15/06/2025 8:21 pm
ASPRINT
(@asprint)
Unfortunately, I had no luck when i decreased the extrusion multiplier to .85
Opublikowany : 17/06/2025 12:11 pm
