USB-C no power
strjan
(@strjan)
USB-C no power
I dont have any power from the USB-C at the back of the printer. Does it need to be enabled  somewhere? I dont want to transfer any data, just power an accessory.
Cheers
Napsal : 23/02/2025 12:17 am
Walter Layher
(@walter-layher)
RE: USB-C no power
There is no power on that connector. I checked this on my MK4 with a USB power meter some time ago. This connector is just for feeding data in for serial printing with e.g. OctoPrint.
You should get some step-down module and connect it to the printer's PSU. There are some mods for that: https://www.printables.com/search/models?ctx=models&q=mk4+usb+power
Napsal : 23/02/2025 1:33 am
strjan
(@strjan)
RE: USB-C no power
Ok, thanks. I thought it was supposed to also feed the camera...
Good, I'll find another way. Thanks for the tip to mods!
Napsal : 23/02/2025 7:06 pm
Walter Layher
(@walter-layher)
RE: USB-C no power
Power in the USB connector can also be a problem with backpowering, like on many Creality printers. Better not to have that.
Napsal : 23/02/2025 7:10 pm
Sembazuru
(@sembazuru)
RE: USB-C no power
Posted by: @strjan
I've looked into this (planning upgrading my MK4S to CORE One eventually) and the camera for the CORE One gets USB-C power from a second board mounted next to the xBuddy board. Our MK4(S) printers don't have that extra board, and I don't see it available as a CORE One spare part on Prusa's web store yet.
The USB-C connector on the xBuddy appears to be USB device only with no USB-PD bidirectional capacity. The USB-C connector on the extra board appears to be power out (5V) only for now. I recall seeing a note on one picture showing the ports that indicates that there may be data on that connector in the future, but I don't know if it will be device only (like on the xBuddy) or host (like on your computer). I'm still trying to find a schematic for that extra board so I can look up the capabilities of the chips on it.
See my (limited) designs on:
Napsal : 26/02/2025 5:06 pm
strjan
(@strjan)
RE: USB-C no power
Ah, ok, now I see, why it is unpowered...
Well, I'll find another way to put the accessories
Napsal : 27/02/2025 4:23 pm
ManelTo
(@manelto)
RE: USB-C no power
This is my option : https://www.printables.com/model/855702-usb-charging-connection-for-mk4-conexion-carga-usb
Posted by: @strjan
Sorry for my poor English. I try to do my best.
Napsal : 27/02/2025 6:49 pm
