Upgraded MK4 to MK4S but slicing with MK4S profile gives "printer model doesn't match"
bluecerberus
(@bluecerberus)
I just installed the upgrade kit for my MK4, but when I switched to the MK4S PrusaSlicer profile, it gives the error in the screenshot. Is this intentional?
Best Answer by Karkovski:
Did you change the printer type in the menu?
https://help.prusa3d.com/guide/6-preflight-check_754328#761379 (Step 4)
Opublikowany : 07/09/2024 11:29 pm
RE: Upgraded MK4 to MK4S but slicing with MK4S profile gives "printer model doesn't match"
Did you load the Mk4S firmware after the upgrade?
as you can see, there appear to be different versions of firmware
Opublikowany : 08/09/2024 9:32 pm
bluecerberus
(@bluecerberus)
Thanks for the reply. I did load a 6.1.3 firmware after I finished upgrading and the filename I downloaded had 'prusa3d_fw_MK4_MK4S_MK39_MK39S_6_1_3.bbf', which seems to account for all of them. But I'll try again.
Opublikowany : 09/09/2024 3:46 pm
Karkovski
(@karkovski)
Member Moderator
Opublikowany : 09/09/2024 4:29 pm
Dustin Doyle polubić
bluecerberus
(@bluecerberus)
Ah, that was it @karkovski, thank you!!! Must have been too eager to start printing again and missed it! 🤐
Opublikowany : 09/09/2024 4:43 pm
Karkovski
(@karkovski)
Member Moderator
I'm glad this was it! 🙂
Opublikowany : 09/09/2024 5:12 pm
bluecerberus polubić
RU's nephew
(@rus-nephew)
I have a question for you. I just got my MK4S upgrade kit and I can't locate instructions specific to installing it on my MK4. The single sheet in the kit seems to point to a document about assembling the entire printer, rather than just the upgrade kit. Which instructions did you use?
Opublikowany : 18/09/2024 2:27 pm
RU's nephew
(@rus-nephew)
never mind. I found them. Stupid me.
Opublikowany : 18/09/2024 2:36 pm
