Tried to update FW from 6.0.0 to 6.1.2, now can't print
LostInTheTrees
(@lostinthetrees)
I took the Prusa USB drive and connected to my MAC (M3 iMac). I copied the firmware to the drive and transferred the drive back to the MK4. Reset and the MK4 came up but did not update.
Then when I put the drive back on the Mac, it says the drive is unreadable and offers to reinitialize the drive. I don't yet.
I plug it back into the MK4. It seems to like it OK but still does not update. Now it won't print, or at least I cannot transfer files to it. I use PrusaLink and every time I try to upload a file to the printer it says the operation is forbidden. I go back and forth like this a few times.
I figure I screwed up the drive somehow and it needs to be reformatted. I am unsure exactly what format the MK4 can use. SO I "erase" the drive on the Mac and set the format to ExFAT, thinking that is an LCD. I copy the BFF file there. I plug it into MK4. I comes up and thinks it has a USB attached but still does not update.
What is the problem here and how do I get updated and back to printing?
And another Q. Is the USB th only local storage on the MK4 that can be used for print files?
-Bob
Best Answer by vhubbard:
USB is the only storage.  MK4 supports USB2, but not USB3.   Must be formated to FAT32,  USB2 drive.
This topic was modified 2 years ago by LostInTheTrees
Posted : 24/08/2024 1:26 am
miroslav.h4
(@miroslav-h4)
RE: Tried to update FW from 6.0.0 to 6.1.2, now can't print
IMHO USB disk must be formated as FAT32.
Posted : 24/08/2024 3:49 pm
vhubbard
(@vhubbard)
Posted : 24/08/2024 3:55 pm
LostInTheTrees
(@lostinthetrees)
Thanks, that did it. The FW update documentation should really mention the format of the usB stick. I looked for the information and could not find it.
-Bob
Posted : 24/08/2024 10:33 pm
