suggestion: some kind of layershift detection!!
i just had my mk4s going for 8 hours, to which it got 80% through and catastrophically layershifted on the x axis after one speck of stray plastic got in the way a few minute earlier, i'd suggest some kind of detection for layershifts that detect any abnormal output FROM the steppers and stop the printing and rehome/park the extruder. I've lost so many hours and materials just to layershifting alone, and there's still no system in place to stop it from ruining a print irreparably.
Currently 3d printers are open loop. The controller sends the move command and assumes it works. If something stops a move, it doesn't know it is out of position.
A closed loop system is needed. A system with measuring devices that track the actual position of the servo or axis. These are normally called "scales" in machine tools. The problem is the cost. There would be a significant cost difference for a closed loop system.
RE: suggestion: some kind of layershift detection!!
fair point, but servos also put out power when moved by something other than the printer, no? it's already possible to detect when the E motor does this, and im just wondering whether something similar would work on the X, Y, and Z.
Bambu does it. Their feature is called layer shift recovery. Not perfect, but it can save an otherwise failed print.
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
