Source for M3nEs Nuts?
JOHNE
(@johne)
My kit came with these fancy nuts which are used to attach things to the frame.  When I google I am not seeing anything like the M3nEs nuts that came with the kit?  Looking for a source in the US.
Nut
Napsal : 21/03/2025 2:21 pm
wikallen
(@wikallen)
RE: Source for M3nEs Nuts?
Search for 3030 T-nuts
Napsal : 21/03/2025 5:44 pm
JOHNE
(@johne)
Yeah I have the old style nuts which would probably work but they aren't that cool.  I am trying to get used to my new upscale world after years in the Creality Ghetto 😀
The Support chat really had nothing.  Thought I would try these.  They don't look the same but the description sounds similar.
M3 Roll in Spring Loaded T Nut
This post was modified před 1 year by JOHNE
Napsal : 22/03/2025 8:38 am
Sembazuru
(@sembazuru)
Another thing to look for are the so-called "hammerhead" or "hammer" T-slot nuts for aluminum extrusions. (80/20 calls them "Standard Drop-In T-Nut"s.) These are designed to be able to be inserted without access to the ends of the extrusion. They drop into the slots and then turn 90° to engage the clamping function. They come in both nuts and studs, depending on the vendor.
While searching for a good article describing hammerhead nuts (I wasn't able to find one quickly that wasn't part of a product description) I ran across a couple articles from what looks like east Asian websites talking about using a hammer or mallet to put the hammer nuts into slots. If the fit is that tight, you've gotten the wrong size nuts. They should drop into the slot easily.
See my (limited) designs on:
Napsal : 26/03/2025 4:06 pm
BigRedLilAl
(@bigredlilal)
I couldn't find any M3, but here are M4 (also see M5 and M6) on amazon - called Roll-in T-Nuts with spring steel spring. Kinda spendy vs standard or the hammerhead version (so you don't have to disassemble for access).
https://a.co/d/fhassYX
Napsal : 11/01/2026 2:52 am
