Slicer profiles without IS for MK4S
Michalizer
(@michalizer)
Membre
Hello,
I would like to ask, if there will be profiles without Input Shaper for MK4S in Prusaslicer. I just did the upgrade from MK4 to Mk4S and after updating the slicer I see that profiles for MK4 without IS are placed in "legacy profiles" and no profiles without IS for MK4S. I really miss the detail print option right now, since my prints are usually around 3h and my preferences are quality or mechanical properties. I very rarely print large part which need the print time saving => using IS is usefull. Upgrade was interesting for me because of improved cooling system mostly. I hope that moving old MK4 profiles to legacy section doesnt mean there will be only IS profiles now... I know this period of time is crazy about printing speed but thats not for everyone. Slower speed profiles always have better quality, printig is less noisy and I believe also printer wear is lower.
So, to summary, Im lookign for profile without IS for MK4S which will work with HF noozle ideally so in case I will need the IS, I will just switch the setting in slicer in the same way as it worked for MK4.
Thanks for any information.
Ce sujet a été modifié il y a 2 years par Michalizer
Publié : 05/10/2024 12:07 pm
1 personnes ont aimé
BryceJ
(@brycej)
RE: Slicer profiles without IS for MK4S
I would also be interested in Non-IS profiles for the MK4S.
Publié : 12/10/2024 3:21 am
Allen8355
(@allen8355)
It doesn't seem like there is.
Publié : 02/11/2024 5:22 am
Brian
(@brian-12)
Out of curiosity why would you want it without input shaping.  It cancels out unwanted motion and improves print quality regardless of speed.
If your just looking to slow it down you can either reduce the speeds in the print settings, or reduce the volumetric flow number in the filament settings.
Id personally recommend using the volumetric flow unless there's just a particular feature you're trying to slow down, for example infill.
Publié : 02/11/2024 2:11 pm
BryceJ
(@brycej)
I was looking for a way to lower the speed as I found on my MK4 the IS sometimes didn't work as well as I liked. This doesn't seem to be as much of a problem on the MK4S and I have used volumetric flow to very good results.
Publié : 02/11/2024 2:54 pm
J.J. Kucharczyk
(@j-j-kucharczyk)
So now I'm sure that downgrade was not necessary for me. 0.1 FAST DETAIL is not quite good for some parts I'm printing. And i think is not so faster than profile on MK4.
Publié : 03/11/2024 9:18 am
