Size problems
I was having issues with tolerances and getting exact fits. When I print out objects they are bigger than expected.
I printed a 25X25X25mm cube along with a 25X25X25mm cylinder.
Neither one is correct when it come out.
Cube X axis = 25.30mm
Cube Y axis = 25.16mm
Cube Z axis = 25.23mm
The cylinder has the same issues.
How can I fix this? I'm assuming one might be a belt, but the others are on the motored axis.
Napsal : 25/05/2025 5:07 pm
Topic starter
answered:
RE: Size problems
I'm going to try this calibration. My print appears perfect, but maybe there is a rogue multiplier.
https://help.prusa3d.com/article/extrusion-multiplier-calibration_2257
Napsal : 02/06/2025 6:55 am
