Screen flickering on prusa mk4s preassembled
Seite 1 / 2
Battle Marden-Anderson
(@battle-marden-anderson)
Mitglied
Screen just stays black and randomly flickers after connecting with prusa connect during a print. Couldn't find anything on this for the mk4s, is it the same as the issue with the mk4?
Dieses Thema wurde geändert Vor 2 years von Battle Marden-Anderson
Veröffentlicht : 30/10/2024 9:11 am
MarkusRe
(@markusre)
RE: Screen flickering on prusa mk4s preassembled
I've ordered my MK4S first day available and have had similar issue. Prusa support guided me to do some tests and finally send a replacement screen.
Veröffentlicht : 30/10/2024 12:01 pm
Mitglied
Did the replacement screen fix the issue?
Veröffentlicht : 30/10/2024 1:52 pm
jetsiah
(@jetsiah)
Mitglied
I’m having the same issue. It just started today after a few days of perfect operation. I checked all cables and connection plus tried to disturb them to replicate and fix the problem with no change. I wondering if its a hardware or firmware issues. Prusa any help with this? Thanks
Veröffentlicht : 31/10/2024 2:08 pm
iftibashir
(@iftibashir)
Same issue - I just get the attached. After several restarts it works normally again.....
Veröffentlicht : 02/11/2024 1:10 pm
iftibashir
(@iftibashir)
Have been asked by Prusa chat to apply the alpha firmware:
https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.2.0-alpha1?utm_medium=chat&utm_campaign=link-shared-in-chat&utm_source=livechat.com&utm_content=www.prusa3d.com
Veröffentlicht : 02/11/2024 1:24 pm
Brayton Thompson
(@brayton-thompson)
Mitglied
Is this the same problem you all are having?
I built the printer from a kit roughly 5 days ago I think and it was great until today when I checked on a print via the prusa app on my phone. Came outside to remove the parts and found this. I was able to start a new print via connect.
I notice that when it reboots the boot screen is fine so I suspect the screen itself is fine and this is some sort of bug in the firmware (i really hope thats the case at least since i don't know if i have it in me to rebuild the printer right now after having just finished.)
Will let you all know if it resolves itself on its own.
Veröffentlicht : 03/11/2024 10:13 pm
Brayton Thompson
(@brayton-thompson)
Mitglied
FWIW i managed to get my screen working again by powering down the printer via the switch on the PSU, then unplugging the machine, then toggling the power switch back and fourth about 10 times. When it rebooted the screen came up like normal. Def thinking firmware bug and not hardware issue. Will trying playing with the app again to see if I can recreate it.
Veröffentlicht : 03/11/2024 10:34 pm
EddiePrints
(@eddieprints)
Mitglied
Same flickering issues led me to this thread.
I just installed 6.2.0 alpha2 and flickering is gone.
When I tried to print a gcode I sliced with MK4S profile, the printer warned me about 'nozzle not high flow'.  I simply re-enabled it in the menu (under hardware, it was disabled) , it's printing OK now.
Veröffentlicht : 06/11/2024 6:28 am
iftibashir
(@iftibashir)
Posted by: @eddieprints
Exactly the same here - seems to be OK since the alpha firmware. And I had the same thing with the HF Nozzle message too 😉
Veröffentlicht : 06/11/2024 9:53 am
EddiePrints
(@eddieprints)
Mitglied
Oh it's going bonkers now! lol
Still printing OK though, the screen is just posessed.
Veröffentlicht : 07/11/2024 12:53 am
iftibashir
(@iftibashir)
Only happened for me when initially switched on, not mid use - but apply the 6.2.0 firmware I linked to above - it seemed to fix the issue for me........
Veröffentlicht : 08/11/2024 11:54 am
EddiePrints
(@eddieprints)
Mitglied
Mind got to a point where it was constantly screwed up, totally unusable screen.
Jumped on chat with Prusa Support a couple of days ago, we did a few tests and I sent over pics and videos of the screen and my wiring.  They're sending me a new screen and cable.
Veröffentlicht : 08/11/2024 12:00 pm
EddiePrints
(@eddieprints)
Mitglied
New screen and cable arrived today.
Only replaced the screen, and so far no flickering issues to report.
I will keep an eye on it over the next few days and report back.
For anyone else having the same experience, please chat with Prusa Support, they are excellent help.
Veröffentlicht : 15/11/2024 8:04 am
Muldjord
(@muldjord)
I have the same issue as you guys. It always happen when I start a print. The screen starts to flicker like crazy and then starts showing inverted images, squeezed image, noisy image and other artifacts. Simply pushing the "RESET"  button on the display panel instantly turns it back to normal and I can start a print no problem, so I recon it's not a faulty display, nor a loose connection.
Looking forward to the next firmware update which, hopefully, fixes this. Love the printer otherwise! 🙂
Diese r Beitrag wurde geändert Vor 1 year von Muldjord
Veröffentlicht : 18/11/2024 3:37 pm
Pedro Reis
(@pedro-reis)
Mitglied
Hey there! Just had this issue as well, re-flashed the firmware and didn't do anything. I did however do something that made the issue go away. I believe it was in the Settings > Hardware > Screen Refresh Rate, changed it from High to Low. Didn't flicker anymore after that, might be useful to someone!
Veröffentlicht : 27/02/2025 5:38 pm
3 weiteren Personen gefällt das
kstor
(@kstor)
Mitglied
You saved my day, thank you
Veröffentlicht : 15/03/2025 9:43 am
kosa
 kosa
(@kosa)
Mitglied
I've had the same problem twice. The first time was 3 days after I had assembled the printer (kit), about 3 months ago. The second time was just today. This time I  had shut the printer down due to a trip, and today I attempted to fire it up and print a model, only to see the bootloader and then a blank screen. Like the troubleshooting had gone the previous time, I disassembled the screen panel and attempted to re-sit the cables. It did not work and I contacted the support a second time. The waiting time was about 24 minutes, so in the meantime I attempted to shut the printer down from the PSU switch, and from the reset button more than 20 times. I even downloaded and installed the latest firmware (6.2.3 - March 25, 2025) but it did not solve the issue. As soon as the chat session started, the screen menu came up and I was able to navigate to a couple menus, but soon it would turn black again. Eventually, the support advised me I turn the Display Refresh Rate to Low (from the Hardware Settings) which I did, and after that the display has remained on and functional
Veröffentlicht : 04/04/2025 6:07 pm
RedFog
(@redfog)
Mitglied
I fully support the method of changing the screen refresh rate setting to low. Yesterday, after 3-4 days of using the printer, my screen also started flickering, distorting, flipping, and was almost impossible to use. It was very difficult, but I managed to change the screen refresh rate to LOW in the settings and everything was fixed.
Veröffentlicht : 22/07/2025 6:57 pm
Donald Bell
(@donald-bell)
Mitglied
This fixed it for me. Thanks Pedro!
Posted by: @pedro-reis
Veröffentlicht : 04/08/2025 10:52 am
Seite 1 / 2
