PSU - What's the maximum safe depth for the M4 screws?
I'm making a mounting frame to fix the PSU to the rear of a V2-style Lack enclosure, and to keep it secure in the frame I need to use the two M4 screw holes the normal construction uses to attach it to the printer's square frame. I want to make sure that when I'm using it, and especially if I publish it to Printables, that the screws used don't end up being dangerously close to any live mains wiring. Does anyone know what the safe depth is for them?
Opublikowany : 12/11/2024 9:50 pm
