Prusa Slicer Filenames
When you Send to Connect in Prusa Slicer a filename is generated using the Output Filename format: settings in the Print Settings tab....Instead of {input_filename_base} can this be changed to the specific Part/Object name? I have many objects in a project and it gets boring renaming every time you go to print. Thanks any help.
Postato : 14/03/2025 3:13 pm
RE: Prusa Slicer Filenames
"Output filename format" under Print Settings => Output options
Postato : 14/03/2025 3:19 pm
1 persone hanno apprezzato
