prusa connect message "material does not match"
energiezwerg
(@energiezwerg)
Membre
I'm using a mk4s with mmu3. And in the past it worked perfectly. But after factory reset, reconfiguring and loading the Prusa Connect ini file "prusa_printer_settings.ini" I get this message.
Does anyone know what this means? Currently I'm only using PLA.
Publié : 21/02/2025 12:40 pm
RE: prusa connect message "material does not match"
What's it showing as loaded on the printer Dashboard in Connect?
Publié : 22/02/2025 12:12 pm
energiezwerg
(@energiezwerg)
Membre
Thanks for your answer.
This info is not displayed for me. But it is enabled. Where i have to set this?  Enclosed my Dashboard.
Publié : 23/02/2025 7:28 pm
cantankerouc
(@cantankerouc)
Membre
I'm getting the same warning, also don't have any "loaded filament" displayed. To me it looks like the MMU doesn't have any information about what the filaments are, and is defaulting to giving the warning. It's also possible that because I only have three filaments loaded, the last two are guaranteed to be "wrong" if they are being counted as a null for the MMU. Ran a two-color print yesterday while ignoring this warning. I had my settings in prusaslicer matched to the correct filaments, and did not run into any problems.
Publié : 28/02/2025 7:39 pm
Alan
 Alan
(@alan-4)
Membre
I have similar issues with Connect miss-reporting printer status on MK4 S without MMU3. Recently it started miss-reporting of either after a material change (i.e. PLA to PETG), or after a nozzle change (0.4 to 0.6), even though hardware was all correctly configured. The most annoying issue is that when the printer is 'Set Current', slicer profiles are all changed to wrong settings. This seems to be a PrusaConnect problem rather than anything else. Seems to be fine if uploading prints via PrusaLink or directly by transfer to USB.
I mostly use Connect via the Slicer Tab
Ce message a été modifié il y a 1 year par Alan
Publié : 02/03/2025 10:05 am
Jean-Sebastien Lemay
(@jean-sebastien-lemay)
Membre
you most likely flashed to the new firmware? Here is what you need to do:
1- unload filament
2- reload filament and selecting the appropriate material
3- run a print already on your usb drive matching the material you just selected
4- once the print file has loaded to the printer and its doing the bed calibration , cancel the print.
You should be all set now ... let me know it it solved your issue
PS - if you have an mmu do the same thing but load to nozzle and select the appropriate material then continue to step 2
Publié : 02/03/2025 8:34 pm
mjkobb
(@mjkobb)
I seem to be having this problem as well this evening. I tried Jean-Sebastian's steps, but after canceling the print and going back to Connect, it still complains that the material does not match.
I'm not sure if this is the cause, but I ran a small print and it came out terribly. This was with PETG and the 0.4mm nozzle. The print could be crumbled in my hand. It was sliced for PETG, and the printer says it has PETG in that nozzle and displays PETG in the lower corner of the screen, so I would think that Connect complaining about the material type should not be an issue...
Publié : 07/03/2025 10:09 am
dukestah
(@dukestah-2)
I'm facing the same problem, no matter what material I load, Connect shows PETG all the time. MK3.5 with MMU3 and 'Load to nozzle', selected the correct material (in current case PA) but Connect keeps telling me that the printer has loaded PETG. This is a nuisance, I know, and the printer is using the correct print parameters set by the GCode but it would be great to get this fixed.
Publié : 30/04/2025 10:33 am
Azonic3D
(@azonic3d-2)
I'm having this same issue. I'm trying to print Prusament PETG-CF. There was no profile for this on the printer, so I created "Custom" and set the temps appropriately (interesting that the Material Guide states the bed temp should be 90deg, but the PrusaSlicer Filament profile says 85deg). I have Prusament PETG-CF chosen in the filament profile. Then clicking "Send to Connect" I get the "Material does not match" message. The screen on the Core One shows that the PETG-CF is loaded as well
Publié : 06/06/2025 3:10 am
Azonic3D
(@azonic3d-2)
As a follow-up, I went into the Filament settings in PrusaSlicer, and simply typed in the exact name I had set up on the Core One under Filament Type, and it made the "Material does not match" go away, but I have no idea if the print will come out correctly. Here goes nothing!
Publié : 06/06/2025 3:53 am
