printing profile issue
SmalLabs.net
(@smallabs-net)
Hello everyone,
I have a problem with the print profile. From prusa connect if you click at the top on "printer ready" or "preferred printer" automatically loads on prusa slicer a profile for the generic non-HS mk4s.
What are the differences between the HS profile that I imagine stands for hight speed and the other without HS?
Also with the profile inserted by prusa connect I also have the three dots under the profile in prusa slicer that indicate whether the printer is working or not. With HS profile no.
I attach pictures to understand better.
Best Answer by Jetro:
HF stands indeed for high flow, this is because the MK4S now ships with a high flow nozzle. You need to select the correct version, same version that is installed on the printer, in the slicer.
This topic was modified 2 years temu 3 times by SmalLabs.net
Opublikowany : 21/08/2024 1:14 pm
SmalLabs.net
(@smallabs-net)
RISPONDI: printing profile issue
HF* hight flow ?  (not HS sorry )
Opublikowany : 21/08/2024 2:23 pm
Jetro
(@jetro)
RE: printing profile issue
Opublikowany : 21/08/2024 2:48 pm
