Print did not resume after filament change.
p3rr1ff3ry
(@p3rr1ff3ry)
Mitglied
Firmware 6.1.4 that came with my recently assembled MK4S.
I unloaded the filament after it ran out about 20% through a print.  I clicked YES for "was filament unloaded successfully".  Then the display showed 0% and asked again to unload filament.  I was not able to re-load filament, it did not auto feed when inserted into the extruder top hole.
I was not able to re load a new filament spool and was not able to resume the print.  I had to abort and restart the print, wasting many g of filament : (
Veröffentlicht : 23/12/2024 2:17 am
circlesmiler
(@circlesmiler)
RE: Print did not resume after filament change.
I had a similar problem with my upgraded MK3.5S. The filament was not "unloaded" correctly. I was lucky because I could remove the filament manually. I think that's maybe not that easy with the MK4S. 🙁 Hope they will fix this issue.
Veröffentlicht : 23/12/2024 10:54 pm
miroslav.h4
(@miroslav-h4)
Clean the sensor and calibrate the filament sensor on the Nextruder.
Veröffentlicht : 24/12/2024 9:03 am
