Nozzle presets for 0.2mm nozzle
VaguePariah
(@vaguepariah)
Utenti
I'm looking at the Config Wizard and the smallest nozzle preset size is 0.25. It has 0.25 thru 0.8. I could have sworn folks were talking about 0.2mm nozzle presets in older forum posts and 0.2mm is super common. Everything is updated in the wizard as far as I can tell. I feel I'm missing something obvious. Any help would be appreciated.
Postato : 30/10/2025 7:58 pm
Michał Niedźwiecki
(@michal-niedzwiecki)
Utenti
RE: Nozzle presets for 0.2mm nozzle
Where did you get the 0.2mm nozzle? Is this nozzle compatible with the Nextruder? I want to buy it for testing printing small fonts. If I get it, I will share the results of my experiments and settings.
Postato : 06/11/2025 9:24 am
Thorsten Lachmann
(@thorsten-lachmann)
you can buy 0.2mm V6 Nozzles at eBay. for Example: https://ebay.us/m/XJG3K6
I used the 0.2mm hardend Steel nozzle, but was not very satisfied with the heat flow in the use with PA12-CF, where it is necessary to have a constant temperature control. With Composite material you can´t just higher the temperature by 10° because then the pastics is too liqurd and seperate from carbon or glass fabric.
In my case I had to take more care at volumetric flow at slicing, then it was okay.
Soon I will try the brass/stainless combination mozzle or which I find very interesting is the 0.25mm Cooper Chrom Zirconium nozzle.
My Printables models including Nextruder improvements: https://www.printables.com/@ThorstenLach_1801966
Postato : 27/11/2025 11:42 pm
