new user with MK4S / MMU3 and the overcurrent warning
Andreas
(@andreas-22)
Utenti
Hi there,
new user here with a new MK4S and a MMU3 bought as kit.
Assembly went well, some multi material prints finished, but now i get the over current warning.
Managed to get it away again by switching the printer off for some time and disconeccting the MMU, but now it is back again.
Without the MMU the printer is running fine.
I think my errror is somehow related to the FINDA sensor, because if i mount it to far in, so the led stay off and reboot, i get the overcurrent warning.
Tried to restart without the motors of the MMU connected, still get the error. What could be pulling more than 3.6A (thats what doc states as warning level) on the MMU board alone?
And can anyone confirm that pushing the FINDA sensor in to far and reboot causes the problem?
MK4S / MMU3
Postato : 15/02/2025 12:04 pm
Andreas
(@andreas-22)
Utenti
RE: new user with MK4S / MMU3 and the overcurrent warning
forgot to mention :
Firmware printer 6.2.0
bootloader 2.3.5
Firmware MMU3 3.0.3
Buddy Board version 37
MK4S / MMU3
Postato : 15/02/2025 12:06 pm
Brian B
(@brian-b-3)
Utenti
I've been running into the same issue for the last couple days. My printer and MMU came assembled but all of the firmware and versions are the same. The issue for me first started when the software on the printer crashed and I was getting the overcurrent error on restart. So far, just letting the printer stay off for several minutes to an hour or two has resolved it temporarily, though I would like a better resolution too.
Postato : 18/02/2025 7:57 am
Richard Magee
(@richard-magee)
Utenti
Hello, Info: mk4s with MMU3 was purchased assembled. Prusa Enclosure was purchased, not assembled.
I have experienced this the for second time and was wonder if anyone else had the same experience or any info.
Basically what has happened is this:
1) Print completed and cooldown (no problems up to here)
2)Opened encloser doors
3) went to reach for the knob to navigate to "finish print"(whatever it says to finish print and get to the "home Screen") when I did this my hand touched the enclosure first, which caused a static discharge into my hand and the printer restart(reset,Bootup,etc...).
4)Upon start up (after it self restarts) MMU3 over current Alarm Occurs
to fix the alarm i just turned the power off for a little while and back on (can't confirm as i did not turn the printer back on this time)
I will be trying to recreate this again tomorrow(Video to contact prusa with)  , but wanted to know if anyone has any info or had the same experience. Thanks
Postato : 18/02/2025 11:12 pm
RoastedChicken
(@roastedchicken)
Utenti
Many people have this issue, including me, I tried several things (without trying any of the solutions that involved soldering) but nothing seemed to really work, even turning it off for over 48hours did not do anything anymore this time
you could try a temporary (or permanent) grounding wire, that did the trick for me by just connecting the LCD ground wire and one of the MMU board mounting screws
more details: https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/3947
for me recreating the problem is very easy, just hit the reset button and the overcurrent problems shows up after boot
Questo post è stato modificato 1 year fa da RoastedChicken
Postato : 21/02/2025 12:09 pm
Rexroo The Owl Knight
(@rexroo-the-owl-knight)
Utenti
was anyone able to resolve this? or is the best solution to just add a grounding wire between the MMU and LCD ground wire?  Currently, I just turn off my printer and leave it off for about half an hour and then it will boot up fine but I would like not to have to do that every time I need to restart the printer or if I turn it off.
Postato : 28/02/2025 7:35 pm
LarGriff
(@largriff)
The issue finally has been properly diagnosed and resolved.  Replace C96 on the xBuddy board with 100nF capacitor.  Prusa has just recently become aware of this but hasn’t yet committed to a course of action.
https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/3947#issuecomment-2665954658
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Postato : 02/03/2025 8:06 am
Utenti
good to know I do not have any way to solder currently so will have to see if any of my friends can do that
Postato : 03/03/2025 2:26 pm
LarGriff
(@largriff)
Looks like Prusa is finally fixing it!  Yay!
https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-general-discussion-announcements-and-releases/6-2-3-alpha-firmware-for-original-prusa-mk4s/#post-739371
Postato : 07/03/2025 2:17 pm
