Multi part delete during printing
Is there any way to delete or skip a part, in identical multi part prints and yet continue and finish the others.
I had one of 10 parts break loose from the build sheet. Would be nice to mark and skip over the bad part without starting over or trying to remove the filament as it extrudes in the missing part space.
Thoughts,
Thanks Mike
Posted : 18/03/2025 12:02 am
RE: Multi part delete during printing
Yes you do it from the printer. It's in the menu.
Posted : 18/03/2025 12:05 am
Topic starter
answered:
Thanks, I wasn't aware. I'll check it out.
Mike
Posted : 18/03/2025 12:08 am
Brian liked
You can also cancel from Prusa Connect if you use that. It’s even easier than canceling from the printer; you can see the objects graphically and choose the one(s) you want to cancel. 😉
Posted : 18/03/2025 1:10 pm
