mk4S X-Axis Pully bearing
Armand
(@armand)
Hi;
Does any one perhaps have the following measurements for the  mk4S X Axis Pully bearing:
Supporting Belt Width:
Flange diameter:
Diameter where belt runs:
Bore:
https://www.prusa3d.com/product/pulley-with-bearing/
I 'm trying to source one locally in my Country as to order just this part from Prusa would be over kill
Thanks in Advance
Best Answer by jan.d.slay:
Measuring would be much faster.
But well... does that help you?
https://www.printables.com/model/1136281-prusa-xl-modified-left-and-right-y-carriage-for-to
Napsal : 21/01/2026 7:52 am
1 lidem se líbí
miroslav.h4
(@miroslav-h4)
RE: mk4S X-Axis Pully bearing
And you don't have an old pulley and a caliper? But that would mean some work and so you better ask others, right? Otherwise, the most common pulley is available in any store with parts for 3D printers.
Napsal : 21/01/2026 9:30 am
1 lidem se líbí
jan.d.slay
(@jan-d-slay)
Napsal : 21/01/2026 11:25 am
Armand
(@armand)
Yep you are absolutely correct,  I can measure it , and would be probably faster , its just I have some prints running at this stage and wanted to get a spare so long , but will strip the X axis ones the prints are done. Just funny that Prusa support does not even know what the measurements are, hence why I just popped the question here
Napsal : 21/01/2026 12:30 pm
1 lidem se líbí
Armand
(@armand)
Posted by: @jan-d-slay
Thanks for the link...... this seems what I was looking for
Napsal : 21/01/2026 12:32 pm
1 lidem se líbí
jan.d.slay
(@jan-d-slay)
I'm glad to hear that. 👍 👍
Napsal : 21/01/2026 12:37 pm
