mk4S X-Axis Pully bearing
Hi;
Does any one perhaps have the following measurements for the mk4S X Axis Pully bearing:
Supporting Belt Width:
Flange diameter:
Diameter where belt runs:
Bore:
https://www.prusa3d.com/product/pulley-with-bearing/
I 'm trying to source one locally in my Country as to order just this part from Prusa would be over kill
Thanks in Advance
Best Answer by jan.d.slay:
Measuring would be much faster.
But well... does that help you?
https://www.printables.com/model/1136281-prusa-xl-modified-left-and-right-y-carriage-for-to
RE: mk4S X-Axis Pully bearing
And you don't have an old pulley and a caliper? But that would mean some work and so you better ask others, right? Otherwise, the most common pulley is available in any store with parts for 3D printers.
Quick start printing for Prusa XL and Prusa Core One
Comfortable display working height on the Prusa Core One
Reducing metallic resonance noises on the Prusa Core One
Yep you are absolutely correct, I can measure it , and would be probably faster , its just I have some prints running at this stage and wanted to get a spare so long , but will strip the X axis ones the prints are done. Just funny that Prusa support does not even know what the measurements are, hence why I just popped the question here
But well... does that help you?https://www.printables.com/model/1136281-prusa-xl-modified-left-and-right-y-carriage-for-to
Thanks for the link...... this seems what I was looking for
I'm glad to hear that. 👍 👍
