MK4S - print speed?
mas
 mas
(@mas-2)
MK4S - print speed?
HI - the software lets us go up to 200% speed (which works really well!) but the dial lets us go to 1000% ! should we try this  ?? are there any detrimental reasons (other than build quality !) such as printer damage potential please??
Opublikowany : 25/09/2024 5:33 pm
RE: MK4S - print speed?
Hi Mas,
the printer has default maximums in the firmware, which should limit the maximum speed to safe limits.
these limits will come into effect as the dial reaches higher numbers.
Opublikowany : 25/09/2024 7:45 pm
mas
 mas
(@mas-2)
thank you - so im ok to experiment up to the full 1000% ?
Opublikowany : 25/09/2024 7:54 pm
I believe so, but you may be disappointed by the lack of speed  increase at higher values
Opublikowany : 25/09/2024 7:56 pm
mas
 mas
(@mas-2)
ok great - thanks loads 🙂
Opublikowany : 25/09/2024 7:57 pm
