[MK4S] PLA nozzle clogs after a few layers – tried everything, still stuck
Jan-Martijn
(@jan-martijn)
Mitglied
Hi all,
I’m reaching out here in the hope that someone can help me solve a really frustrating issue with my Prusa MK4S. For the past few weeks, I’ve been battling persistent nozzle clogs while printing PLA — and I’ve truly tried everything I can think of to fix it.
Here’s what’s happening:
Whenever I start a print, the first few layers usually go just fine, especially when it’s the first print after turning the printer on. The lines look okay, extrusion seems normal — but then, a few layers in, the printer starts struggling. The extruder motor begins clicking, and filament stops extruding completely. At that point, the nozzle is clogged, and the only way to continue is to unload and try again.
I thought it was bad filament at first, but I’ve now tested multiple high-quality PLA brands, all properly stored and dry. The issue happens with every single one.
Thinking it might be a worn-out nozzle, I replaced it — not once, but three times:
The stock nozzle that came with the MK4S upgrade kit
Two E3D High Flow Brass 0.4mm nozzles
Still no change.
Then I went even further:
I ordered and installed a completely new Nextruder hotend assembly, including:
A new heater block
A new thermistor
A new heatbreak
A new nozzle
This entire section of the printer is now essentially brand new. But… the problem still persists.
I also performed a cold pull (multiple times), adjusted the extruder tension screws, verified the fan function and self-tests, recalibrated the Z-offset, and followed Prusa’s gearbox calibration guide to the letter. Nothing helped.
Loading filament even manually feels tough — there’s clearly more resistance than there should be. And what really stood out: the filament often curls at the nozzle tip and sticks to it, even when loading or extruding during prep.
The strange thing is: it always starts well. It just fails progressively as the print continues. That makes me wonder — could this be heat creep, even though the fans are working fine and I’m not printing inside an enclosure?
At this point, I’ve even completely disassembled the entire Nextruder, inspected everything, and reassembled it from scratch. Still the same issue.
To summarise what I’ve tried:
Replaced the nozzle (3x)
Replaced the full hotend
Replaced the thermistor
Tried various brands of PLA
Performed cold pulls
Disassembled and reassembled the extruder
Verified fan function and cooling
Gearbox calibrated and extruder tension adjusted
Adjusted Z-offset and print temps (tested 210–235°C)
Clean bed, open environment, no enclosure
I’m honestly out of ideas. I don’t want to keep replacing parts without understanding the root cause. The fact that even loading filament requires force, and that it only works briefly before failing, tells me something’s not right — but I have no clue what.
Has anyone seen this kind of behavior before? Any idea what else I can check or try?
Thanks so much for reading and for any advice you can give.
Jan-Martijn
Veröffentlicht : 07/08/2025 3:51 pm
Otto
 Otto
(@otto)
RE: [MK4S] PLA nozzle clogs after a few layers – tried everything, still stuck
pretty much the same on our MK4 in the company using PETG. No glue why?
At home I have been using a MK3 and never seen such problems...
Best regards,
Otto
Veröffentlicht : 20/08/2025 6:04 pm
Mike B
(@mike-b-3)
@jan-martijn , you clearly have been methodically working through possible causes and trying logical things.  Don't give up!  My first 3 or 4 thoughts were dispelled once I read all the actions you took...
I'm uncertain though what you mean by "Loading filament even manually feels tough — there’s clearly more resistance than there should be."  Are you loading through PTFE tubing, or directly into the nextruder at the top?  Perhaps all this resistance is coming from the filament path before the nextruder?  It's the only thing I can think of that you haven't investigated (or haven't mentioned investigating)...
Veröffentlicht : 20/08/2025 9:24 pm
pink_clown
(@pink_clown)
Did you try temperature changes or different print profiles? I expect you do not print in enclosure. This could make i filement during print more preheated inside the enclosure. How about the temperature tower? Did you try?
Veröffentlicht : 21/08/2025 5:29 am
Otto
 Otto
(@otto)
well. as far as I am concerned, we are using a prusa enclosure and have been printing without those issues for about 2 years.
but trying without ptfe tube is a good thing, I think (tough we are preparing a mmu right now and then we will need the tube back)...
Veröffentlicht : 21/08/2025 6:35 am
pink_clown
(@pink_clown)
Never print with PLA inside the closed enclosure! Even the PETG can create the clog. For PLA or PETG leave the door open.
Veröffentlicht : 21/08/2025 2:14 pm
Otto
 Otto
(@otto)
well. we have been printing PETG with closed doors for about two years without issues.
today we tried without the PTFE tube - looks promising, first small print worked...
Veröffentlicht : 21/08/2025 2:43 pm
Mike B
(@mike-b-3)
I once had a PETG print clog (only once) inside the enclosure, so I started leaving the door open or propped a bit ajar to keep the temps down.  But in the last 6 months I have been leaving it closed again and still no clogging issues.  I wonder if the clogs are actually made worse by the enclosure.  I understand that a warm environment might make the cooling of the fan less efficient, but we're talking 35C vs 20C cooling a 200C+ hot end...
Veröffentlicht : 21/08/2025 6:58 pm
