MK4S +MMU3 + 6.40 Alpha FW - Stuck at Reloading Filament - 99% Parking
Seite 1 / 3
JGeiger2024
(@jgeiger2024)
Printer gets stuck with status of 99% Parking.
After starting a print, the temperatures reach preheat, bed leveling executes, extruder heats to temp, extruder produces purge line at the left front of the build plate, then lifts and moves to the right.  Sequence halts at the 99% parking state.  The only recovery is to RESET.
Anyone seeing this?
Veröffentlicht : 23/09/2025 3:31 am
3 weiteren Personen gefällt das
fskifte
(@fskifte)
Mitglied
RE: MK4S +MMU3 + 6.40 Alpha FW - Stuck at Reloading Filament - 99% Parking
I see this to after firmware update to 6.4.0-alpha+11774
its not on all prints it happens
but when it happens I do power off/on and started the same print .. then it runs flawless.
hope for fix in next firmware
Veröffentlicht : 23/09/2025 8:17 am
BeKay1211
(@bekay1211)
Mitglied
Seems like this did not get fixed on the RC
Veröffentlicht : 23/09/2025 4:22 pm
James Kirk
(@james-kirk)
The same here on my mk4s with the alpha-firmware.
After a reset it works without problems
Veröffentlicht : 23/09/2025 6:02 pm
Mike B
(@mike-b-3)
This happened to me last night.  It's weird - I "paused" the job from Prusa Connect, no change.  I "cancelled" the job from Connect, still no change.  But I was able to get it out of the stuck state (at least from a UI perspective) and was moving around the menu, although I don't think any menu items were able to be clicked.
I pushed the reset button and restarted the print after clearing the plate and it worked fine.  Definitely looks like a bug.
Veröffentlicht : 23/09/2025 9:41 pm
Papyjo
(@papyjo)
Idem with 6.4.0-RC+11796 😮
Veröffentlicht : 25/09/2025 6:10 pm
iibex
(@iibex)
Mitglied
Hey there,
Same here, only a reset seems to be the option for me to get things running again.
Firmware: 6.4.0-RC+11796 --> Previous firmware version I noticed the same issue by the way.
Will this "bug" be noticed by the Prusa development team reading this forum? Or would we need some extra action trigger to them?
Veröffentlicht : 27/09/2025 8:58 am
a message on the Github page may be more Fruitful.
Veröffentlicht : 27/09/2025 10:20 am
iibex
(@iibex)
Mitglied
Thanks, I will do so.
BTW: I reversed the firmware to 6.2.6. The problem isnt occuring anymore it seems. n=1 so no proof yet I guess.
Best, Jeroen.
Veröffentlicht : 28/09/2025 7:20 am
LarGriff
(@largriff)
Posted by: @joantabb
I would have thought this was Prusa’s “official” forum; after all it is linked by their website whereas GitHub is not.  This issue was pointed out here before the latest RC was released.  But GitHub is where Joe Prusa hangs out.  Doesn’t seem like he values these opinions much.
Diese r Beitrag wurde geändert Vor 7 months 3 mal von LarGriff
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Veröffentlicht : 28/09/2025 3:06 pm
Prusa devs don't read the whole forum; they do seem to read replies to release announcements for a while but to report effectively GitHub is best.
Veröffentlicht : 28/09/2025 3:17 pm
Papyjo
(@papyjo)
MK4S + MMU3 + Prusa Brass Nozzle - 0.4 m FW 6.4.0-RC+11796- Filament Jam Detection: ON ;Single Brass Nozzle Setting
With Prusa Nozzle brass CHT - 0.4 mm and adequate parameter (high flow) in the config the blocking seemed less frequent but happens in the middle of a prints (3x).
Return to previous firmware?
Veröffentlicht : 28/09/2025 6:54 pm
Of course, that's the whole point of an alpha or beta release: report the issue (github) and return to stable software until there is another pre-release to test.
Veröffentlicht : 28/09/2025 7:06 pm
Mike B
(@mike-b-3)
I spent some time searching, but I can't find a GitHub Bug report for this issue.  Anyone have a link?
When this happens, I notice that it purges a lot more filament at the start of the purge line than normal.  I haven't had it happen twice in a row, either - after the reset, re-printing either from Connect or the front panel seems to work.
Veröffentlicht : 12/10/2025 7:49 pm
Mike B
(@mike-b-3)
Sigh - I went back and searched again and found it right away:   https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/4862
I was hoping to find some hint of how to avoid this issue (other than downgrading the FW).  But none of the dev discussions are public I guess.
Veröffentlicht : 12/10/2025 7:58 pm
Ali
 Ali
(@ali-4)
Mitglied
Same here but it did it when my print was 75 present done any way to restart it where it was. or is the print lost now.
Veröffentlicht : 19/10/2025 12:52 pm
ServerGuy2008
(@serverguy2008)
I encountered this same issue and posted in the GitHub bug report.
Veröffentlicht : 20/10/2025 3:34 am
GerryPB
(@gerrypb)
I am currently having the same issue very often.
Veröffentlicht : 09/11/2025 2:27 am
tp
 tp
(@tp-2)
Mitglied
m2
Veröffentlicht : 29/11/2025 8:18 pm
darkmattermaker
(@darkmattermaker)
This seems to be a MK4s-specific issue as I've run into this also on my MK4S. It happened quite frequently. However, I've since upgraded the MK4S to a Core One via the conversion kit and the problem hasn't returned. If you're running a MK4S you'd be better served by reinstalling 6.2.6 until this is fixed.
Veröffentlicht : 30/11/2025 12:34 am
Seite 1 / 3
