[Gelöst] Mk4s linux??
Blazej Szczygiel
(@blazej-szczygiel)
Mk4s linux??
i need help with setting up mk4s in prusaslicer. when selecting available printers i only see mk4. question is it possible to set up mk4s?
Veröffentlicht : 18/10/2024 12:45 pm
Blazej Szczygiel
(@blazej-szczygiel)
RE: Mk4s linux??
Ok, I managed to solve the problem with linux 22.04.1 LTS
1.check if you have the right linux installed ( 22.04.1 LTS)
2.donload file from:
 https://github.com/prusa3d/PrusaSlicer/releases/download/version_2.8.1/PrusaSlicer-2.8.1+linux-x64-newer-distros-GTK3-202409181416.AppImage
3.once you have uploaded the file, open
terminal and type in the terminal:
sudo apt install libfuse2
4.wait for the installation to finish.
5. go to the folder with the downloaded file and, hovering over the file, click the right mouse button, then properties, at the bottom, mark the executable file as the program.
6.now click on the downloaded appimage installation file and allow  Installation.
after installation it is possible to select the MK4S printer in the configuration.
problem solved..
Veröffentlicht : 19/10/2024 12:17 am
