MK4 to MK4S upgrade problem. Print nozzle is higher than cooling fan
HowardHo
(@howardho)
I'm in the process of upgrading a MK4 to MK4s using the upgrade kit.  It all comes together fine put there is a problem with the printer nozzle sitting above the cooling fan shield if the nozzle is raised where the instructions says it should go.  The instructions say the "copper ring on the nozzle should not be visible if it's properly seated." (pg 83 of the instructions).  But if I do that the Fan-shroud sits below the nozzle.  To make it work properly the copper ring needs to be showing about 5mm.
I'm sure everything was installed correctly.   BTW, although the instructions are impecable and the kit is the usual Prusa quality,  I'm not impressed by the fan holder as it bends too easily.
How can I correct this?  Are there any other adjustments other then the needle height?
Thanks,Needle sit below shroud but the copper  tube on needle also is showing. Needle sit below shroud but the copper tube on needle also is showing.
Opublikowany : 19/07/2025 12:18 am
Walter Layher
(@walter-layher)
RE: MK4 to MK4S upgrade problem. Print nozzle is higher than cooling fan
Can you show us some photos of this? Perhaps this would help finding the problem.
Opublikowany : 19/07/2025 8:58 am
HowardHo
(@howardho)
Sorry, I included a pic but evidently my skill in using the forum is not as good as it should.  Here is the pic sent.
Notice the nozzle is sitting a little proud of the cooling fan.  But there is much more copper ring length then how much the nozzle sits below the cooling.  It amounts to I can't raise the nozzle enough to hide the copper ring and have it below the fan shroud.
Hopefully someone can help.
This post was modified 10 months temu by HowardHo
Opublikowany : 19/07/2025 3:03 pm
Walter Layher
(@walter-layher)
This looks like the metal mount brackets for the fan are not inserted all the way in.
Opublikowany : 19/07/2025 4:02 pm
3 ludzie polubili
HowardHo
(@howardho)
Bingo!  That was the problem.  Didn't realize it because it seemed pretty solid.
Thank you so much.
Opublikowany : 19/07/2025 6:03 pm
2 ludzie polubili
