Missing Filaments in Slicer
aholub
(@aholub)
Mitglied
I just upgraded the Slicer to Version 2.9.2, and the only filament in the dropdown is generic PLA. What do I need to do to get a full filament list? Thanks!
Veröffentlicht : 17/04/2025 5:17 pm
aholub
(@aholub)
Mitglied
RE: Missing Filaments in Slicer
Also, I did run the Configuration Assistant and chose the filaments that I wanted, but they still don't appear in the dropdown. Are there step-by-step instructions anywhere?
Veröffentlicht : 17/04/2025 5:54 pm
Walter Layher
(@walter-layher)
Look in Configuration > Configuration Wizard > Filaments (in the navigation panel on the left hand side). Select away and confirm.
Veröffentlicht : 17/04/2025 6:13 pm
Walter Layher
(@walter-layher)
Did you run through all the steps of the Assistant? Including selection of your printer type and the nozzles? Or did you just select the filaments you want and clicked on "Finish"? I always click on "Next" until the last screen and do not click on "Finish" right away if I just want to make a change in just one of the panels. Not sure if that makes a difference but it works for me like that.
Veröffentlicht : 17/04/2025 8:56 pm
