M262-268 codes not recognized.
Marek Wolf
(@marek-wolf)
when using codes M262, M263, M264, M265, or M268 I see on the console output "echo:Unknown command M26x var var
For example when entering M262 P7 B0 it returns echo:Unknown command: "M262 P7 B0"
This is happening with firmware 6.1.2 and 6.1.3.
Anybody else see this or know of a fix?
Respondido : 14/12/2024 3:52 am
Harry271
(@harry271)
Miembro
RE: M262-268 codes not recognized.
IMPORTANT: To utilize the full potential of the GPIO board you need firmware 6.2.0-alpha1 or newer.
https://help.prusa3d.com/article/gpio-module_734695
Respondido : 14/12/2024 1:43 pm
GavinCampbell
(@gavincampbell)
I'm guessing you are trying to use these codes with the GPIO board.  You will need to run firmware 6.2.0-Alpha1 min.
Respondido : 14/12/2024 2:14 pm
