Issue with hot end temperature - Idle at more than 100 degrees C but it is at room temperature
paveuuu
(@paveuuu)
Membre
Hello all,
I have a weird issue, recently my hotend is at more than 100 degrees C after the booting.
I tried to play with the cable to see if there is any connection issues but the temperature did not changed. I tried to unplug / plug the temperature sensor connector but no success. I also rebooted and flashed an older firmware but the issue persist.
I measured the internal resistance of the sensor and it varies from 97k to 102k on idle. Which seems normal.
I am a bit lost ... is the loveboard or the xbuddy board dead ?
Publié : 07/04/2025 12:33 pm
pink_clown
(@pink_clown)
What is shown on the display when you disconnect the senzor?
How long did it work before the incident?
The temperature senzor is NTC type - higher temperature -> the lower resistance. 100k is at about 20-25°C.
It is connected to the xBuddy, the loveboard only consolidates all inputs into the main xBuddy- loveboard cable. 100°C points to the short circuit.
A shot could be to reload the FW, but I give it a low chance.
Try to change the hotend and heatsink thermistor plugs ( they are next to each other) and they have similar characteristics - to see what happens.
Publié : 14/04/2025 5:57 pm
1 personnes ont aimé
