IP address setting
I have one heretical question: How can I set a static IPv4 address on the Ethernet port? If I use DHCP, the address is assigned. If I set a static address, the IP stack settings disappear and there is no way to set it. Or at least I haven't found a way to do it. Firmware 6.5.3 If this has been discussed here somewhere or there is a guide for it, then I'm sorry, I couldn't find it.
Best regards
Zbyněk
Veröffentlicht : 03/06/2026 12:06 pm
How to set a Static IP Address from Prusa's support pages...?
... it's not heresy, or I'm as guilty as you 😀
Diese r Beitrag wurde geändert Vor 3 hours von ssmith
Veröffentlicht : 03/06/2026 4:40 pm
