Filament Jamming
Infoteq
(@infoteq)
Filament Jamming
I'm mid-print (10 of 12hrs), towards the end of the third spool of the same filament (CookieCAD PETG Pink Star Stuff) and out of the blue I get a filament jam. Now this is pretty common since 6.4.2 (i think) where it got more sensitive or whatever and I usually just reload and off I go, but in this case it just got worse. I tried clearing the nozzle with a cleaner tool and that helped for about 30sec of print time. Now I'm stuck with this behavior where I can't even get it to extrude to attempt continuing and I am at a loss as to why. Here is a video showing the behavior. I even tried subbing in some PLA that I've never had any trouble with from a partially used spool, but it exhibited the same behavior.
On the vendor site they said jams were common, but after 2 and 3/4 spools of this filament, I'm not sure that is really the issue. Any advice would be appreciated. There's already some minor defects as a result of these shenanigans, I'd hate to lose the whole job.
Opublikowany : 28/05/2026 12:59 pm
