Fan duct file?
I woke up this morning to a blob that destroyed my fan duct and hotend assembly. I am getting replacement parts in on Monday and need to print a new duct and fan holder (I knew that thing was going to be a disaster when I "upgraded" it from the MK4). Can you point me in the direction of those files? I don't even see the duct in the replacement parts on the site.
Is it printed out of ASA?
Opublikowany : 02/10/2024 4:05 am
1 ludzie polubili
RE: Fan duct file?
Hi, printables files for MK4s are located here: https://www.printables.com/model/451500-mk4smk39s-printable-parts/files in section Nextruder . (fan case/cover, fan shroud) The recommended filament is PC-CF, but ASA will work as well.
Opublikowany : 02/10/2024 6:23 am
RE: Fan duct file?
Hey guys had the same problem woth the filament. What type were you guys using? I was using the 3dbuddy filament package.
Opublikowany : 08/11/2025 4:00 pm
