Default infill in 2.8.1?
Is there a way to set a default infill pattern in prusaslicer 2.8.1? It seems they switched from gyroid pattern to square in recent updates and I do prefer the gyroid pattern. I would like to set it as the default if possible, any thoughts?
Opublikowany : 18/10/2024 6:16 pm
RE: Default infill in 2.8.1?
Not really No. That's not how the slicer works. Just make the settings on a print profile whatever you want and then save the profile as a custom one. Just cant save with the same name as ANY of the system ones. You can have as many as you like.
You can do it if you want to manually edit the profile dependencies but any changes you make will get over written the next time they are updated. But you have to know what you are doing with that. If you have to ask the question then you don't 🙂
Opublikowany : 18/10/2024 6:35 pm
