Beep on Pause
Mordeth
(@mordeth)
Beep on Pause
Hi all, I print 50+ small parts with PETG on a single bed at a time. I'm using Jessie PETG with the default Jessie profile. My infill is 50%. I've found that I can't escape the nozzle build up problem. I am aware that I'm pushing the boundaries and this just might be inescapable given what/how I'm printing.  All that to be said that I've taken to adding pauses after each of the first 5 solid bottom layers, but I need the printer to make a beep when it has paused. Is there a way to add a beep into the G-Code or is there a setting I've missed? The printer is set to LOUD.
Thanks!!
Posted : 30/10/2025 1:21 pm
https://help.prusa3d.com/article/prusa-firmware-specific-g-code-commands_112173
Scroll down to M300
But you shouldn't be getting buildup - how are you drying your filament?
This post was modified 14 hours ago by Diem
Posted : 30/10/2025 1:38 pm
Mordeth
(@mordeth)
RE: Beep on Pause
Hi Diem, I'm drying the spools for 12 hours in a poly dryer on the medium heat setting, then it feeds from a poly box through PTFE tube into the printer.  My hydrometers read between 10 and 15% usually.
Checking out the M300 now.
Thanks!
Posted : 30/10/2025 2:28 pm
