Bed leveling & issues of loadcell
gyuchul moon
(@gyuchul-moon)
Utenti
Hi, I tried to resolve the issues, but I don't have a solution, so I need some help.
Recently, I found an issue during printing: the left corner lifted slightly and became slightly higher than the other sides.
I thought the problem was with the sheet, but it was slightly lifted at the bottom(the original plate).
So I manually adjust some of the levels, with bolts and nut,s but it seems to work. After that, It happens loadcell issues
after printing 10mm; all layers print the loadcell issues( all layers touching the loadcell)
Does anyone have these issues? Even the Prusa MK4s offers bed leveling, but for the best quality, I want to adjust some of the layers so I have fewer concerns after printing.
I found some tips on online with rubber pad and springs, but after setting up Idk how to let the mk4s know the default level of z axis.
It seems no problem during probing, this situation keep happens, so I roll backed the original setup, but it happens again
Does it have any tips for solving the physical bed leveling and loadcell issues?
Questa discussione è stata modificata 6 months fa da gyuchul moon
Postato : 03/11/2025 5:34 pm
