Bed leveling compensation during printing.
kevin1954
(@kevin1954)
MK4
During printing does the firmware slowly "even out" the uneven bed areas?
I other words example, if the left side of a print (bed) is 0.01 mm lower than the right side, as the print progresses "layer by layer" does the firmware compensate just a little on each layer, to "remove or zero" the printed surface so as the print finishes, the "top surface of the print" is level to the printer X/Y axis movements not level to the actual print bed?
Sorry, this is hard to describe.
Some printers call it the "fade height".  Example if 20 mm then in 20 mm of print height the actual print will become "level" to the printer.
Thanks
Respondido : 01/10/2024 5:13 pm
