Bad Layer, looks over-extruded in both x & y-axis
The problem started 6 prints ago with the "stuck filament when not stuck" problem others are seeing. I checked the typical others suggested, x-axis needed to be tightened. The bad layer was happening at ~12.5mm (z-axis) before adjusting the belt, it's now at ~20mm. I did have 2 good prints after adjustment but this is today's bad layer.
What should I look for now?
Napsal : 22/07/2025 1:41 am
