After upgrading to 6.2.4+8909 I can no longer upload files to MK4S
userprintly
(@userprintly)
Mitglied
I'm getting this error when attempting to upload a sliced bgcode to my printer:
Filename contains invalid characters
This only happened after I upgraded firmware to 6.2.4. The auto-generated filename contains "," as far I as can tell wasn't present in previous filenames. But even when I remove the "," I still get the same error.
The filename is autogenerated, so it seems odd that it would complain about being unable to parse a file PrusaSlicer created.
I am using PrusaSclicer-2.9.2, and both the application and configuration are up-to-date (Configuration > Check for {Configuration, Application} Updates
Veröffentlicht : 14/05/2025 4:07 am
RE: After upgrading to 6.2.4+8909 I can no longer upload files to MK4S
The comma is a valid character. If you can upload the zip compressed 3mf project file we can see if we can reproduce the issue.
Veröffentlicht : 14/05/2025 12:57 pm
userprintly
(@userprintly)
Mitglied
Thank you for taking the time to read, respond, and offer help!
I tried a few different projects and all failed so I don't think that was the cause. I ended up tracing the cause down to the USB stick which got corrupted during or after the firmware flash. After re-formatting the drive I was able to successfully print the project. So all good here.
Thank you again FoxRun3D!
Veröffentlicht : 15/05/2025 6:50 am
