USB stick gets corrupted
citsejam
(@citsejam)
Hi Prusa Community,
my MK4s was working flawlessly until recently, where the (original Prusa) USB stick started to get corrupted and neither the printer, nor the PC could read it.
After reformating the stick on the PC, it worked fine again until I ran into the same issue again 2 weeks later.
Is this a known problem?
Does it help to buy a new (better quality?) USB stick or is this a firmware-bug corrupting the stick?
Best Answer by Walter Layher:
Do you use the feature for power loss recovery on your printer? In that case the printer will save the state of the printing progress after every completed line/command in the (b)gcode file. If you check the number of lines in such a file you'll get a very high number. That is a lot of write operations. USB sticks were not initially intended for this kind of use. That is also why they are not recommended for use as a system drive on a computer. They will wear out and fail eventually. SD cards generally can tolerate more write cycles, so the suggestion by @hyiger to use SD cards instead is appropriate.
Napsal : 30/10/2025 12:28 pm
Posted by: @citsejam
Hi Prusa Community,
This is known problem. Same thing happened to mine. Eventually they "wear" out. This is what I use with my printer, it works well and is perfect for devices like the printer: SanDisk 16GB Industrial MLC MicroSD
Napsal : 30/10/2025 11:57 pm
1 lidem se líbí
RE: USB stick gets corrupted
And I use this as well: Micro SD Card to USB Adapter
Napsal : 31/10/2025 12:03 am
1 lidem se líbí
citsejam
(@citsejam)
Posted by: @hyiger
This is astonishing.
Neither did I plug the stick all the time - I was using wifi, so maybe plugged it 10 times in total.
Nor did I write excessive amount of data - I think I barely scratched 500mb on the stick. As I never deleted something, I also did not write to the same memory cells over and over again.
So do they just age, no matter how hard they used? Or is the printer using too high voltages and frying the stick?
Would the issue being resolved with an SSD-Card or would I run into the same thing in 2 years?
As I never had any issues with USB sticks on my PC, I just try to understand what exactly is going on here 🙂
Napsal : 31/10/2025 8:42 am
Walter Layher
(@walter-layher)
Napsal : 31/10/2025 2:07 pm
1 lidem se líbí
BillR
(@billr-2)
Hi All,
Yes, I feel your pain as mine did this more times than I would care to count!
I am thinking there may have been a bad batch of these out there as I gave up on the Prusa USB drive altogether and have been using a Sandisk Cruzer 16MB USB drive now for about three months and has worked flawlessly, so my suggestion is scrap the Prusa drive and replace with reputable and high speed brand.
Napsal : 31/10/2025 2:20 pm
citsejam
(@citsejam)
Awesome explanation, that totally makes sense to me now 🙂
I will order an SD Card and adapter, as proposed by hyiger.
Thank you for both of your answers 🙂
Napsal : 31/10/2025 2:58 pm
Bobby Carter
(@bobby-carter)
I have had the same problem with MK4S . I switched to micro SD,  card and problem solved.
Napsal : 15/12/2025 1:22 pm
Träd-E
(@trad-e)
How is this actually turned off?
Posted by: @walter-layher
Napsal : 27/12/2025 7:05 pm
Walter Layher
(@walter-layher)
I found a post on Reddit about that: https://www.reddit.com/r/prusa3d/comments/13479of/how_to_turn_off_power_loss_recovery/
I have not tested if this works as described since I am not using this feature. I print via OctoPrint where it does not work, because there is no buffering on to the USB drive. In fact I only plug in an USB drive for updating firmware on my printers.
Napsal : 27/12/2025 7:17 pm
t5montecarlo
(@t5montecarlo)
My USB stick got corrupted a couple of months ago. The only thing I could think that did it was removing it from the machine while it was on. I only did that one time and then later I noticed I couldn't update the firmware. I thought the firmware file was bad. I reformatted the stick and was able to update the firmware.
Prusa i3 MK4S Kit in Lack Enclosure
Napsal : 04/01/2026 9:30 pm
citsejam
(@citsejam)
Unplugging an USB device without disconnecting it can never corrupt the whole stick.
It can only corrupt recently written files, if they are still cached and not yet completely written.
As the printer does not write files (besides the before mentioned temporary print-log), there is no need to turn the printer off
Napsal : 05/01/2026 12:29 pm
t5montecarlo
(@t5montecarlo)
In my case the FAT was the likely culprit; many of the filenames were gibberish.
Napsal : 08/01/2026 2:20 pm
Laban
(@laban)
536Personally, I've had several USB drives corrupted by my MK4S printer. The last one became completely unusable; it was impossible to format.
All the drives were brand-name (Verbatim, Corsair, etc.).
I had to format the drive for it to work again. I'm now using a USB adapter with a microSD card slot.
My USB drives were never unplugged from the printer; I used network file transfer. I abandoned the USB drive format, and since then, things seem to be better; in six months, no crashes.
MK4S / MMU3Elegoo Mars 4 ultra
Napsal : 04/02/2026 2:51 pm
JayPrints
(@jayprints)
I’ve had 2 of the original USBs that came with my Prusa printers go bad in the first week. I would honestly just buy a new one…SanDisk is reliable.
Napsal : 17/03/2026 11:48 pm
