Upload has failed. There is no suitable storage found at xx.x.x.xx
Steve Webre
(@steve-webre)
Miembro
Folks,
Printer preforms flawlessly but will not accept a file directly from PruasSlicer even though connected via Prusa Connect and actively seeing printer.  Original Prusa memory stick installed in printer with lots of open memory and happily transfers files using the stick.  Just won't accept files directly.  Thanks for any help!
Respondido : 01/02/2025 10:39 pm
1 les gusta
strjan
(@strjan)
RE: Upload has failed. There is no suitable storage found at xx.x.x.xx
I had something similar. The usb drive died shortly after.
Respondido : 27/02/2025 7:09 pm
1 les gusta
miroslav.h4
(@miroslav-h4)
Posted by: @steve-webre
Folks,
A completely normal situation. Remove the flash memory, and insert it back after a while, or reset the printer.
Respondido : 27/02/2025 9:22 pm
1 les gusta
Alas that's true although clearly it shouldn't be. But I see it at least once a day. Why? No idea. The USB sticks are all fine. Usually it recovers quickly.
Respondido : 27/02/2025 9:39 pm
1 les gusta
Freelancerakash11
(@freelancerakash11)
Miembro
good for that
Respondido : 03/03/2025 6:58 pm
iteran
(@iteran)
Miembro
Tried removing the USB and powering the printer off and resetting the password etc, but I keep getting the same error. How else do I troubleshoot this?
Respondido : 16/12/2025 8:10 pm
SweetRide
(@sweetride)
On mine, when this happens the IP address of the printer changes.
Go into your printer network settings and look at the IP address. Compare it to the IP address setting in the physical printer portion of your slicer.
The last two digits will change occasionally. Not sure if mine is special ED or its a normal thing.
Respondido : 17/12/2025 5:50 pm
strjan
(@strjan)
I have it too. Sometimes another try helps, or printer reboot.
I also had issues with some corruption, reformatting the USB stick in the PC fixed it.
Respondido : 18/12/2025 9:13 pm
