Upload has failed. There is no suitable storage found at xx.x.x.xx
Steve Webre
(@steve-webre)
Folks,
Printer preforms flawlessly but will not accept a file directly from PruasSlicer even though connected via Prusa Connect and actively seeing printer.  Original Prusa memory stick installed in printer with lots of open memory and happily transfers files using the stick.  Just won't accept files directly.  Thanks for any help!
Napsal : 01/02/2025 10:39 pm
1 lidem se líbí
strjan
(@strjan)
RE: Upload has failed. There is no suitable storage found at xx.x.x.xx
I had something similar. The usb drive died shortly after.
Napsal : 27/02/2025 7:09 pm
1 lidem se líbí
miroslav.h4
(@miroslav-h4)
Posted by: @steve-webre
Folks,
A completely normal situation. Remove the flash memory, and insert it back after a while, or reset the printer.
Napsal : 27/02/2025 9:22 pm
1 lidem se líbí
Alas that's true although clearly it shouldn't be. But I see it at least once a day. Why? No idea. The USB sticks are all fine. Usually it recovers quickly.
Napsal : 27/02/2025 9:39 pm
1 lidem se líbí
Freelancerakash11
(@freelancerakash11)
good for that
Napsal : 03/03/2025 6:58 pm
