Sliced 3MF not recognizing separate bodies
Hi all, I designed my file in SW to with separate bodies having extruded the bodies without merging the results. But after I slice this model, it doesn't show the separate materials when I run the slider up and down. Any ideas? If I haven't given enough information, let me know! Thanks in advance.
Opublikowany : 09/09/2025 1:50 am
The usual cause is not enough tolerance; if the gap is too small the slicer assumes it's a single body.
Opublikowany : 09/09/2025 10:45 am
