Topic starter
answered:
RE: Print Area
Re,
A little up ?
Is it my setting or a problem on the machine ?
Thanks for your help
Postato : 24/12/2024 3:48 pm
The I3 line and now the Core One all use the same sized build-sheet, you have one of the recent generic sheets. When buying a Mk2.5/3/4 you (used to) get a specific sheet with graphics for that model but if you have several machines and share build-sheets the print area doesn't exactly overlap. It can also vary very slightly with different kit builds.
The slightly conservative build area setting for your printer is in the slicer and with careful measurement you can often gain a few square millimetres but that setting will be printer specific.
Postato : 25/12/2024 6:34 am
Topic starter
answered:
RE: Print Area
Many thanks, I will check settings.
All the best
Postato : 26/12/2024 8:05 am
