Overall Height ?
Harry Edwards
(@harry-edwards)
Overall Height ?
Hi folks.  Can someone please tell me the overall height of the MK4 with a filament spool attached .  I need to see if this printer will fit on my bench with a spool attached.
TIA.  :harry
Posted : 04/09/2024 5:17 pm
An assembled MK4/S, MK3.9 printer measures 500×550×400 mm | 19.6×21.6×15.7 in, and 7 kg, without filament spool.
But the additional height depends on which spoolholder you use and on the size of the spool - if height is likely to be an issue then a ceiling/undershelf (shelf above) spoolholder can be used together with a low profile filament guide to feed from the side and deliver from above.
Posted : 05/09/2024 1:13 am
