Nextturder issue
3DX
 3DX
(@3dx)
Nextturder issue
I think my next truder is broken. I had some filament stuck and after I pulled it out, I'm not sure if something was damaged during this.
Is there supposed to be a filament guide at the bottom (red circle) or does it look ok?
Opublikowany : 27/02/2026 9:46 pm
mnentwig
(@mnentwig)
RE: Nextturder issue
Correct, parts are missing left and right of the metal nozzle. But you still may be able to print it yourself if you guide the filament in manually.
The part in question is considered a consumable with MMU (and if it makes you feel any better, even before my MMU I ran into the same nextruder-blob-issue but fortunately managed to clean it up. Anyway, consider it part of the more-or-less typical learning curve).
Note, you'll need the nextruder gear assembly tool before trying to replace it.
Opublikowany : 27/02/2026 10:30 pm
I appreciate the thread title... 😉 Whether it's an expression of disappointment with the Nextruder, a pictorial description of its output, or just a simple typo, it had me grinning.
Opublikowany : 28/02/2026 6:48 am
1 ludzie polubili
