More on the ongoing stuck filament issue.
brianjordan
(@brianjordan-2)
Prusa MK4S - built from kit in April ‘25
Nozzle 0.4mm Hiigh-flow
Firmware 6.4.0
After 8 months of ownership and printing ,according the the printer stats, 2.5Km of filament, mainly PLA with some PETG and a little ASA, I have finally encountered the stuck filament issue.
Yesterday I was printing a large PETG object taking a little over 11 hours when I saw the problem; it first started around 50 minutes into the print and recurred at intervals of between 3 and 20 minutes. Each time I followed the on-screen prompts to unload and reload the filament and each time the print continued after extruding some filament, albeit with a surface imperfection visible at that point.
Eventually, against my better judgement, I disabled the stuck filament sensor and set it running again. The resulting print was flawless until, within an hour of the end, I heard something; a new sound which I haven’t heard or seen reported before...
When the nozzle was in one particular region there was a rasping or rubbing noise. The print didn’t stop so I continued to watch it to the end and after the print ended I inspected it and found that, confined to the region where the printer had been making this noise, the surface had a distinct roughness unlike the flawless surface formed after I disabled the stuck filament sensor. The rough area is close to and on one side of a seam which may be relevant?
I’m writing this in the hope that someone smarter than me can explain why the machine printed apparently flawlessly between disabling the stuck filament sensor and the sudden appearance of the odd noise and rough print.
I should add the this is with a new (less than 10 hours use) nozzle.
B
Dieses Thema wurde geändert Vor 5 months 3 mal von brianjordan
Flashforge finder -> Flashforge Creator Pro -> Prusa MK3S -> Prusa MK4S ->???
Veröffentlicht : 20/12/2025 3:32 pm
LarGriff
(@largriff)
RE: More on the ongoing stuck filament issue.
My guess is that if you look at the region where you heard the rasping or rubbing noise, you’ll find that the bottom surface was curling upwards as it slowly released from the bed due to poor adhesion.  As it curls up, the top surface also rises slightly but just enough to where the nozzle is now dragging through previously deposited layers.  The extruder has to work harder to push out the filament, and that triggers the “stuck filament” error.  Turning off the detection allowed it to run but didn’t fix the root problem of poor adhesion.
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Veröffentlicht : 20/12/2025 3:44 pm
brianjordan
(@brianjordan-2)
I don't believe this is a 'curling up' issue as the region is on a vertical surface high on the print [1] .However your comment that the extruder is working harder for some reason is probably right, maybe somehow the extruder is trying to push more filament than is needed? I shall try printing the top of the model again; first with the stuck filament sensing off to see if the problem can be reproduced and, if so, I'll enable the sensing to see if the same region triggers stuck filament alerts.
[1] x between 200 and 210, y between 75 and 125, z between 80 and 115 (mm)
I didn't describe the problem fully for which I apologise. The attached image might help.
Posted by: @largriff
Veröffentlicht : 20/12/2025 5:27 pm
LarGriff
(@largriff)
A picture is worth 1000 words!  I think there may be two different things going on, probably unrelated.
You may have a partial clog in your HF nozzle.  Have you tried doing a cold pull?
As for the odd noises, I don’t know.  Maybe just harmonics?
Best of luck!  Every day is a new adventure in 3D printing!
Veröffentlicht : 20/12/2025 8:37 pm
Please show us the underside of that failed print.
Veröffentlicht : 20/12/2025 10:48 pm
brianjordan
(@brianjordan-2)
I can't do that, sorry. The bulk of the underside of the print was support material which has been removed and binned, I don't think it showed any imperfections or evidence of poor adhesion to the powdered satin sheet. Some of the model was on the bed and inspecting it I can't see any issues.
For info I am attaching an image of the first layer from the slicer.
B
Posted by: @diem
Veröffentlicht : 21/12/2025 11:09 am
goetzpil
(@goetzpil)
Mitglied
I also have big problems since a few weeks. I also use the 0,4 HF nozzle.
If I disable the stuck filament sensor, 95% of my prints are perfect, but I dont want to keep it disabled all the time.
It happens more often without MMU (higher printing speed) and if I use the standard 0,25 Speed settings. At 0,25 Structure or 0,20 Speed it does not happen as often.
Prusa Support told me to increase the temperature in 3° C steps, I use the official prusa filament profile for the elegoo rapid PETG (250 - > 253 °C) . I did also reduce the flow to 0,99 - 0,98. That helped but it still gets stuck regularly.
At the moment I create my own profiles, a mix between speed and structure for the printing speeds. A very good setting, I think in advanced mode, is the (overall) maximum printing speed.  At the moment I set it to 180. At the 0,25 speed profile some printing speeds (perimeter, infill,...) are at 240 and this is apparently to high for this filament or whatever the main issue is..
The room where the printer is has constant ~16 °C and 30% humidity, I dont dry my filament before printing, I think 30% is ok for PETG? I use the enclosure and I have done many cold pulls already..
Veröffentlicht : 16/01/2026 6:41 am
