layer shift
tishihtzu
(@tishihtzu)
layer shift
I woke up this morning expecting to see a finished print job; however, I was not expecting this.
It appears roughly half-way through the print the layer shifted 9mm in the X axis:
Print shifted in the +X axis 9mm.
Posted : 14/08/2024 12:04 pm
tishihtzu
(@tishihtzu)
RE: layer shift
I guess I forgot to attach the media...
Posted : 19/08/2024 1:27 pm
Walter Layher
(@walter-layher)
RE: layer shift
Can you check if the top cover of the Loveboard is attached correctly? If it sits behind the backplate, it can interfere with the frame in case there is a crash detection and the printer does a re-home of the x-axis. The top cover part must sit between the backplate and the Loveboard to have enough clearance.
Posted : 19/08/2024 2:08 pm
RadekP
(@radekp)
RE: layer shift
Maybe this ?
Enable "Steeper ramp before obstacles" (printer/extruder configuration) by default - when disabled unpredictable crashes/layer shifts occures #13235
https://github.com/prusa3d/PrusaSlicer/issues/13235
Posted : 19/08/2024 4:28 pm
tishihtzu
(@tishihtzu)
RE: layer shift
It's only happened this once-- so must have had something out of the ordinary happen.
Posted : 17/09/2024 6:48 pm
tishihtzu
(@tishihtzu)
RE: layer shift
No it is seated correctly.
steve457
(@steve457)
RE: layer shift
I've had some random layer shifts occasionally as well and haven't been able to pinpoint the problem. No obstructions and belts are properly tensioned. I actually was upgrading my MK4 to a MK4S and found one of the parts that Prusa provided in PCCF had a layer shift problem. So apparently this even happens to them at times.
Posted : 23/09/2024 11:24 pm
