Fix for First Layer Issues & Filament Stuck on MK4S with MMU3
AD
 AD
(@ad-2)
Hi everyone,
I recently tackled some problems with my new MK4S and MMU3. My first layers were rippling because the nozzle was too low, and my filament kept getting stuck, triggering the filament detection alarm.
After trying a few fixes like adjusting the idler tension, tightening the XY belts, and changing the nozzle—none of which worked—I finally solved it by adjusting the Z offset to +0.06mm. This completely fixed the first layer and the stuck filament issues.
I'm sharing this here to help anyone facing the same problems and to find out if others have had similar experiences or have other solutions to suggest.
Thanks!
Publié : 20/03/2025 11:32 pm
RE: Fix for First Layer Issues & Filament Stuck on MK4S with MMU3
Long thread on Github: https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/4254
Well-known problem even though apparently many people are not affected by it so it's unclear what's causing it. In my case, I see it on all my MK4S's but have never seen it on my XL (with essentially the same extruder technology). No word from Prusa.
Publié : 21/03/2025 12:07 pm
1 personnes ont aimé
LarGriff
(@largriff)
I set Z-offset to +0.04 on everything I print on the Mk4s.
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Publié : 21/03/2025 3:01 pm
2 personnes ont aimé
AD
 AD
(@ad-2)
Given the recurring nature of this problem across different setups, I think it would be extremely beneficial if Prusa could implement a feature that allows us to permanently save the Z offset adjustment directly on the printer.
Publié : 21/03/2025 11:46 pm
Well, you can set it in the slicer as a permanent offset and save that profile. But that's just a bandaid and not a solution. Plus, at least for me it wouldn't do me much good as my offsets for PLA vs PETG/ASA vs TPU are different.
Publié : 21/03/2025 11:48 pm
AD
 AD
(@ad-2)
Yeah, I’ve been doing the same in PrusaSlicer, but the issue is that it sometimes resets after updates. That’s why I think having the ability to save the Z offset directly in the printer firmware—so it persists even after reboots—would be ideal.
Publié : 21/03/2025 11:51 pm
Rob Lutter
(@rob-lutter)
Membre
Thanks for this thread I was having the same problem after adding MMU3 recently and it was driving me nuts (even though after the first layer I stopped getting the waviness but the bottom of prints were looking ugly). Pretty sure the offset will fix it.
Wonder what's causing it? I didn't move the Nextruder or toolhead down at all? Maybe the different filament sensor? Weiird.
Publié : 19/08/2025 5:36 pm
