6.2.2 Firmware for Original Prusa MK4S
Jan Kratochvíl
(@jan-kratochvil)
Member Admin
Summary
  • Fix consistent layer shifts
  • Fix stack overflow
  • Fix toggling MMU rework in menu
  • Improve network throughput
This is a stable release of firmware version 6.2.2 for the Original Prusa MK4, MK4S, MK3.9, MK3.9S, MK3.5, MK3.5S, MINI & XL, addressing issues identified in version 6.2.0 and 6.2.1. This update is recommended for all users.
We have fixed a regression introduced in 6.2.0-RC1 that was causing consistent layer shifts on some models. We would like to apologize to all users who experienced this and thank all the kind people who reported this issue and provided their models as test-cases for us when debugging this issue.
Please note that not every layer shift is caused by a firmware bug like this. However, if you experience a layer shift that is both consistent between prints (happen in exactly the same place by exactly the same amount) and fixed by downgrading to 6.1.3 firmware, we would like to hear from you.
Fix stack overflow
We fixed a stack overflow blue screen happening when the printer was trying to report that another error screen happened before.
When toggling MMU in the menu the printer didn’t request a filament sensor calibration. This is now fixed.
We have backported two changes that aim to improve network performance. We are postponing sending thumbnails back to Prusa Connect, and we are employing a different allocator for TCP packets.
Release notes:  https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.2.2
Napsal : 05/03/2025 6:15 am
Jim Q
(@jim-q)
RE: 6.2.2 Firmware for Original Prusa MK4S
Thanks for releasing this. Had a bunch of prints ruined this way. Same exact height. It was always with the gyroid infill.
Napsal : 05/03/2025 4:16 pm
CharlieD
(@charlied)
Since upgrading to 2.9.1, having problems automatically logging into account.
Getting message that "Communication with Prusa account taking longer than expected. Retrying (attempt n°).
There is an option to "Stop now" even when login does occur .
Napsal : 12/03/2025 10:27 am
